Old 08-22-2009, 11:01 PM
Thanks for the update Ian!
Old 08-22-2009, 11:11 PM
Great to hear about your motor. Get some pictures putting it back together
Old 08-23-2009, 01:20 PM
IanC's Avatar
IanC IanC is offline
This "rebuild" cost me $249! I sure hope he did a thorough job. He did give me all of my old parts and an itemized list of what he replaced. I guess time will tell.
Again, this motor is a rattle-can special.
Ian
Old 08-23-2009, 11:35 PM
ihnick's Avatar
ihnick ihnick is offline
looks good to me
Old 08-28-2009, 01:52 PM
IanC's Avatar
Got the motor in and running this afternoon. It sounds really nice. No smoke or anything:biggrin2.gif:.
One question though, it seems that the governor won't let the motor run on its own. I mean, I have to keep pressure on the throttle lever or the governor will pull it back down to idle. Does this sound like a cable misadjustment? The gov springs are in the same position as before the rebuild.
I'll try to post some pics this evening.
Ian
Old 08-28-2009, 05:57 PM
IanC's Avatar
Here are a couple of pics almost completely assembled. I still need to clean up my rims, get new front tires and decals. Other than that, it's together.
Anyone have any thoughts as to why my throttle lever won't stay up?
Thanks,
Ian
Old 08-28-2009, 06:56 PM
RPalmer's Avatar
RPalmer RPalmer is offline
IanC,
You did a really nice job! I went back to see how it started. NICE JOB.
I haven't come across a throttle problem like yours, so I'll be watching to see what it is. Again. Nice work.
Old 08-28-2009, 09:11 PM
Did you go through the Kohler governor adjustment procedure? If I remember right you loosen the clamp and then turn the shaft with pliers all the way to one side or the other...the manual says which and I have CRS..
Old 08-28-2009, 10:00 PM
IanC's Avatar
I didn't adjust anything yet. I had this motor gone through and the builder didn't have the tractor there. He just had it running on his stand.
If I disconnect the throttle arm off the carb, I can keep it running no problem. With everything hooked up like it was before the rebuild, it'll rev up and then just rev down. I can keep it running w/ the throttle lever on the dash, but it will NOT stay at a set rpm. Is this a governor issue?
Thanks, Ian
Old 08-28-2009, 10:09 PM
Nice work, Ian! Your 100 looks nice.
