#21
You are lucky, I have been waiting for a 3 pin plate for 6 weeks now, apparently on backorder.
Cub Cadet 1200 A "Few" David Bradleys Sears Suburbans Older John Deeres Couple Gravelys I think it's called ADD |
#22
![]() Quote:
Here's the link seach within the page for IH-117591-C1 http://www.cubclassics.com/cubparts2.html |
#23
Hope you get it all back togeather, up and running again!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#24
Thanks John!
#25
I've changed to title to fit the latest news on this clutch rebuild. The ISO mounts are shot! I have not checked the fronts yet but I have pics of the rear ISO mounts and the effect they are having on the clutch and 3 pin driver. Just like any wearable items ISO mounts do wear out and need to be replaced. I'll have a new set here tomorrow if all goes well.
![]() Some back ground info. I got the clutch reinstalled and the motor was shaking and rattling pretty bad and I noticed that the 3 pin driver didn't have the same amount of pin in the friction disc so I got checking and made sure that there was no problem with the drive shaft itself. Everything checked out ok. So I got looking at the 3 pin driver that I had and noticed that the pins had varing lengths thru the friction disc so I rolled under the tractor to have a look. I was shocked to see that the ISO mounts were wore out already. The PO had changed them last summer and I haven't put that many hours on the tractor so it really cuaght me off guard to see them so worn. I did get some pics of the drive shaft as well. Time for the pics! |
#26
Those don't look like they were replaced last year, they look like they're 30 years old.
#27
![]() Quote:
I was going to remind you to check the ISO mounts and then figured you already had. Sorry. Mine looked like yours.
#28
Duke, that next to last picture looks like the disc's in my spine, ouch. I know how that poor clutch is feeling
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
#29
![]() Quote:
![]() Quote:
