Old 06-30-2011, 07:45 PM
scgtguy's Avatar
scgtguy scgtguy is offline
Default powder coat
Dave ....The following were blasted and coated '
Hood , side panels, drive line tunnel cover, 4 wheels, 2 front castings, dash tower. All sides, top, bottom etc were done ...
Cost me $ 245 .
The only white piece I painted was the dash cover as its fiberglass so I sanded it down and painted it with a ford white (matched the powder coat)
and several clear coats...Done with DupliColor spray cans from the local parts joint.
B.
Old 06-30-2011, 09:03 PM
CC1650Dave's Avatar
Cool, thanks. I wasn't under the impression that you could get a good glossy finish from powder coating (?) Did you do some more work to it after powder coating? I was thinking powder coating for the frame, wheels, etc. but didn't even think it would be feasible for the sheet metal.
Old 06-30-2011, 09:11 PM
scgtguy's Avatar
Default powder coat
no problem on the sheet metal ... it did leave some small pits where there was rust when they blasted it .... so you need sameone with a good hand blasting it ... if you have moderate rust you might want to spray paint it if your looking for an automotive type base coat / clear coat finnish ... while this does shine and is easy to clean up .... it doesn't have that depth to it but does have hard long lasting industrial type finnish.
hope that helps ya
B.
