#21
Yep it is definitely in the way and I knew it, but got carried away and well, while I was taking the pics is when it hit me. The "Doh!" moment, LOL. I still have to get new wire harness, clutch parts, PTO parts, Front and Rear tires, and a battery. Slowly but surely making progress.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
#22
I'll just keep posting updates about the whole 128 process. The motor came together nicely. While waiting on some $$$ for the clutch, PTO, and some other odd ball parts I have started painting each of the pieces as I can. I got started on the hood today. It was nice out this morning, so I took the Strip Eaze and made quick work of the paint on the hood. Got it primed and painted. I have the lower grill already done, I will work on the upper grill panel and and the pedestal in a couple of days. Here are some pics of the progress.
![]() ![]() ![]() ![]() Primered: ![]() ![]() And Painted. Will get a better shot after it dries: ![]()
#23
hmm, paint stripper. Why didn't I think of that? Ha! Looks like it did a good job getting the old paint off.
Looks great primed and painted too! ![]()
![]() -Mark 1978 1450 1976 1450 |
#24
I've been very impressed with it. Found it at Ace Hardware for about $6.
It took everything off of the fuel tank and a few other small items very easily. The hood took a couple of going overs, but was not very difficult at all. I am going to use it on the rear fender panel.
#25
Looks great! Thanks for the update, DWayne!
#26
#27
![]() Quote:
The product you used did a pretty good job, but I guarantee it doesn't hold a candle to the air craft stripper! Paint looks great, keep up the good work!
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
#28
I'll definitely go look for some of that stuff. I am always up for easier products. Thanks.
#29
Yeah that sounds like the stuff to use!
#30
Well thought I would give a few updates, it's been awhile since my last post. In the negative category, the ole A/C bit the dust in this 90 degree heat. Had to do something quick and ended up getting some good window units. The down side to this is I had to use money set aside to finish up the 128,
![]() Got the hood and front headlight grille put together: ![]() ![]() I got the old decal removed from the headlight panel and found several stress cracks that I had to weld up and grind down. It is now nice and straight and will work real good: ![]() Got the hood hinge cleaned, primed and painted today also along with the headlight panel: ![]() I was able to get the PTO lever put back into the steering tower and I took the key switch and glass beaded it and the connector ends and also the key switch cup. Looks like a new one now. ![]() The rear fender pan was a lot of work but I think it turned out real well: ![]() I really had no intention of splitting the frame and transmission, but somehow today while it was in the 90's I decided I needed to seperate them and get the dirt off and then prep for paint. They aren't prepped for paint yet, but I did at least get them apart, LOL. I was about wiped out after all that. ![]() ![]() ![]() ![]()
