Old 09-07-2013, 08:18 AM
The 149 and plow is looking nice!
X2!
Old 09-07-2013, 06:10 PM
johncub7172's Avatar
Cool One of IH Cub Cadet's best built garden tractors
Lots of work going on today. No time for the 72 restoration! Here are a few pictures, and a extremely rare video!
http://youtu.be/vkQLN2flVxQ
Old 09-07-2013, 06:22 PM
Cool pics and vid John!
Old 09-07-2013, 09:22 PM
Thanks Mike, The s/g took a nose dive just on the last load. Would not start so I removed it and the pulley shaft will turn easy, then hard. I think the brushes or bearings went bad. The working volt meter on board shows a charge of about 13.75, so that still was working. The 71 would not start back up, sometimes a click-click, got dark so its in the cub shop. Should be able to come up with a repair in the morning.
I should have stopped and swapped out the s/g when I was hearing funny little noises. Guess in the near future I will be learning how to inspect, test, and re-build the good 'ol Delco Remy!
Old 09-07-2013, 09:58 PM
Enjoyed your pics and vid, John!
Old 09-15-2013, 09:41 PM
finz68 finz68 is offline
Default '62 original sharing a garage
the old timer is getting ballsy...
Old 09-21-2013, 09:55 PM
Default IH Cub Cadet model 72
Pictured here are parts of the 72. The first picture is of the front axel in a white sealer. I had a weld shop weld in the cuts in the axel from the deck drive belt. The following picture is that of the primer in a spray can I thought I'd give a try. Next, you have the axel in this primer photo,.............
Might as well go for the starter generator bracket too. First up is said part in a sealer, lastly is said part in same primer. I finished out the new primer can between the two parts.
Just thought some IH Cub Cadet enthusiast would like to see a model 72, since OCC to be the place to be !
Old 09-21-2013, 09:56 PM
Nice work, John!
Old 09-21-2013, 10:48 PM
EricR's Avatar
EricR EricR is offline
Nice there John, just keep chugging along!
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 09-22-2013, 07:50 AM
Looking good John!
