Old 12-17-2011, 10:17 PM
Nice cubs, guys!
Old 12-17-2011, 11:48 PM
ricks ricks is offline
at long last. the white shepard struck. not with a one-two punch, but just a graze. got a chance to go through the motion of clearing snow, at least. it wasn't much of a challenge, but it sure was fun. i could have done that in a pair of shorts and a t-shirt, my blood was pumping so fast. i did mage to loose a few nuts and bolts, broke a clevis pin and forgot to change the bar on the bottom of the thrower. all in all it went pretty smooth. the plow was on the "original", and it outperformed the 109 w/ the blower. i could have driven through the neighborhood in third gear, clearing the walkway, if it wasn't for the loose bolts. i thought i tightened all those. the blower will be a great addition, once i adjust the runners. it clogged on the first pass which i expected, but i think with the correct bar on there, it will be fine. i used a teflon polish on both the plow and inside the blower housing/shute. it's the same product i use on the hull of my aluminum boat. i think though on the blower, i need to repaint, as the surface is quite rusty and grimy. not the ideal surface to be putting polish on.
enough of the chit-chat, here's some action shots.
Old 12-18-2011, 01:08 PM
Originally Posted by MOturkE View Post
Well, I gone and done it. I let go of the cash and bought a dozer blade for my Cub Cadet 122. It's in average condition, given the age and use it's apparently seen. The PO has a 100 that came with the blade, but he prefers his walk-behind snowblower. I had to drill a couple of holes to move the hanger rod to meet the brackets, I'm using a chain to lift with instead of a rod, and the lifting handle bracket on my 122 is gone (scratched paint suggests it had one once), so I've u-bolted the chain onto the lifting handle for now. Here's a couple of pictures for everyone.
You know, now that I'm ready, it probably won't snow much around here...
That's a great looking blade set up there! I sometimes use a steel cable and some clamps as a lift rod. You can pick up that steel cable at a TSC or local hardware store and the clamps for about $3 and it is rated at about 720lbs. Super deal!
Old 12-18-2011, 01:14 PM
Great action shots! Wish I had some of that snow and some of that fun. We got a tease yesterday, but it wasn't enough. Can't wait to get my snow equipment in action. .....I also look around the neighborhood to clear other people's snow just to get some more seat time since I can get mine done in about 5-10 min......talk about an addict trying to get a fix.
Old 12-18-2011, 04:37 PM
Great pics! Thanks for sharing.
Old 12-18-2011, 05:28 PM
dieseldan123's Avatar
This is how i get my cub snow ready! If we get any snow it wont amount too much like it will anywhere else. If im lucky ill have enough snow to make a pint sized snowman from the box blade.
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 12-18-2011, 05:30 PM
jeryan149 jeryan149 is offline
Default 149 snow fighter
She has loaded ags, weights and chains. I need a set of 3 rib for the front.
John
Old 12-18-2011, 05:34 PM
John
Nice 149! I like the custom paint job and the number decals!
How or where did you get those decals?
Old 12-18-2011, 07:12 PM
Pauld Pauld is offline
Here is my 169 ready for some snow
102 ,129 ,149 ,169 ,154, tiller .chipper
wide frames rule
Old 12-18-2011, 07:32 PM
Awesome pics, guys! They are great looking cubs!
