#191
And fired it up! Ignition was instant, faster than ever before. And the exhaust pipe (sink drain pipe) that I put on quickly began to turn a nice shade of purple. I set the initial idle at 1400rpm and adjusted the idle fuel mix. Let it run for about half an hour at about half throttle and shut it down. Drained the oil again, inspected the magnet on the drain plug, and refilled with Mobil One full synthetic 10 w 30. Let it all fully cool down and re torqued the head bolts to 35 ft-lbs (what do you mean I have to take the fuel tank and fire wall off again!?).
![]() Edit: I have since switched to Shell Rotella 30wt. |
#192
Now I just have to drop the idle down to 1000, set the WOT @ 3600 and adjust the air fuel mix. Should be ready to cut grass tomorrow morning!
From page 10 of the Quiet Line Operators Manual; http://www.onlycubcadets.net/forum/s...0468#post30468 |
#193
I continue to benefit greatly from the valuable information found on this site that is available thanks to a lot of very knowledgeable people, thank you all very much! I am grateful.
http://www.onlycubcadets.net/forum/s...50&postcount=6 |
#194
Aren't the engine tins there to guide cooling air from the flywheel over the head? You may want to reconsider leaving them off.
#195
![]() Quote:
This thread has been really helpful. I am getting ready to rebuild the clutch on my 1000 and I learned a lot here. Being more of a woodworker than a welder I appreciated the hardwood clutch spring compression tool. Thanks! |
#196
Any issues running synthetic 10w-30?
#197
So, j4c11, Years ago some guy at a small engine shop told me that full synthetics were no good in air cooled engines as they coated the cylinder walls, reducing their cooling ability so I have always stayed away from them for that purpose. I use Mobil 1 full synthetic in my work van, Shell Rotella in my big truck and have always used a quality 30 wt in air cooled stuff. Then I found this;
“After approximately 50 hours were obtained on my Kohler, I switched to Mobil 1, 10W-30 synthetic oil. The chrome top compression ring on a cast iron bore takes a while to break in properly, and 50 hours is considered about average. A pure synthetic lubricant in an air-cooled engine is ideal, mainly due to the higher oil temperatures these engines generate when compared to their liquid cooled counterparts. The synthetic maintains a more stable viscosity and offers higher film strengths at temperature plus superior dispersant and detergent additives.” From here; http://www.kirkengines.com/downloads...hlerPartII.pdf So it’s kind of an experiment. p.s. that “some guy” from years ago, he went out of business. |
#198
Interesting, the manual says:
"Straight 30-weight oil is preferred. SAE 10W-30 oil is not recommended above 32F. Using this oil substantially increases oil consumption and combustion chamber deposits. " Which is why I was asking. Keep us posted. ![]() |
#199
![]() Quote:
http://midwestsupercub.net/MWSC2015.pdf Item #10 on page 11. You might want to call them to find out which one would work for your application. |
#200
Looks good! I'd try and get the tins back on it. I have mine off the head yet keep forgetting to get it back on after retorquing last year! Lol and the other cub had a mouse nest built on top of the head after my dad using it for 2 weeks!!! Was the nastiest mess! I don't know about using synthetic oil in there, but tha is your choice. One thing is if it has any leaks they will show up now.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
Tags |
clutch, cub cadet 1200 quietline, rag joint |
