Old 07-11-2009, 07:22 AM
cub149's Avatar
cub149 cub149 is offline
I did remove the decks but not the mule drive/lift carriage. My biggest concern it getting the throtle cable attached correctly. If I set the throttle at idle and incert the cable with the throtle lever in idle, will this have everything set right? I don't have a tach to check this with, is there a cheap one on the market that is good? What are the rpm's supposed to be? I think it is 1600 idle and 3600 top end?
Old 07-11-2009, 08:39 AM
ajgross ajgross is offline
Inactive Member
Just a bit of advise to get to that problem engine bolt. If you have "family dollar" stores in your area, pick up a cheap socket set from them. I would have to look at mine, but I think it comes with a 1/4" drive 9/16" socket that is rather shallow. It made getting to the engine bolts on my 1250 a whole lot easier. As a added bonus, it comes with a very thin walled 3/8" socket that will fit the valve seat in the carburetor. Dollar General might sell the same kit, but I got mine at Family Dollar. I think it cost around $7. The case for it is blue with a clear plstic lid.
AJ
Old 07-11-2009, 07:29 PM
Idle spec in the book is 1000 no load, but I usually do 1250 or so on mine....1000 just seems too slow.
