Old 06-27-2009, 05:17 PM
bombur bombur is offline
Default 129 flexible coupling replacement
Nice catch. I removed the front shaft coupler off the engine and found the pin to be sheared, but enough of the stump was left to keep the shaft turning under load. The cooling air screen was 80 clogged with science project as well. Are pins available locally or are they an IH special blend.
Should this ongoing saga be off line?
Old 06-27-2009, 05:49 PM
You'll need to get that from an IH or Cub Cadet dealership.
Old 06-27-2009, 08:59 PM
It's getting worse. The rear end of the drive rod has worn a side street into the rear coupling so now I have to replace both, I have no idea where to find this stuff. The worn coupling explains how this fiasco started: a wobbly drive rod.
Old 06-27-2009, 09:31 PM
The forum sponsors will have what you need, but see if you have a Cub Cadet dealer near you. We need to keep them in business, too.
Old 06-27-2009, 10:22 PM
clint clint is offline
If you have a friend handy with a lathe you might get the coupling bored, and bushed/sleeved. Can you post a pic of how bad it is ? If you have problems finding one, and the part is not badly worn I might can help you out, however if you can find a good used one, or a new one is not to expensive it would be easier to replace.
Clint
