Old 03-30-2011, 09:19 PM
Southtowns27's Avatar
Southtowns27 Southtowns27 is offline
This may also be useful:
Old 03-30-2011, 09:29 PM
sdk131 sdk131 is offline
Thanks all...I have to admit I was just dwon there staring at her and the idea of splitting her in two crossed my mind. I think that may be my best option at this point. I was using standar flat punches, but this pin won't even budge a fraction of a mm so I don't think peening over the edge is the problem. I think it is truly the poor access I have through the creeper slot.
Tomorrow I'm going to try to break her in two so I can get direct access to everything.
And yes...it is beer time!
Old 03-30-2011, 10:40 PM
william1041200's Avatar
Once the motor is out, the front is very light. You could flip it onto the rear cover plate on wood blocks easily. It is unstable but a little creativity could remedy that with some 2 x 4s then the roll pin is more open to opinion
Old 03-31-2011, 02:04 PM
dyt4000's Avatar
dyt4000 dyt4000 is offline
In a pinch, I've used a bolt that was very close to the diameter of the pin...
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
Old 03-31-2011, 07:45 PM
robpelletier robpelletier is offline
Default to get the roll pin out
to get the roll pin out i made an air chisel bit make it the same size as the pin and to start it put a 1 /4 5/16 socket on the end
Old 03-31-2011, 08:30 PM
Well, I'm enjoying my celebratory beverage right now. I split the tractor in two to get the access I needed to whale on it with a BFH and numerous punches. Thanks to all of you for your sugestions, it certainly sounds like some of you have fought this battle many times before!
