Old 03-30-2011, 08:10 PM
brentwd's Avatar
brentwd brentwd is offline
Just replaced the points and condenser. The points push rod mic'd the same as new so I left it alone. I waited until the points closed and put the probes on the points and the meter went to the right or infinity as Matt described. As soon as the needle moved to the left or "0" I checked the sight hole and lo and behold there was the "S". The motor is out so as soon as I get it back in I will let everyone know how it does. Wish me luck and thanks again DX3.
Old 03-30-2011, 08:26 PM
Sminkey
Guest
Posts: n/a
Good luck on the refire Matt's static method is the best
Old 03-30-2011, 09:14 PM
Fingers are crossed. I think it should do you good now. Sounds like you have it correct..
Old 03-30-2011, 09:21 PM
Southtowns27's Avatar
Southtowns27 Southtowns27 is offline
Found the sight window on my 149... It's a little hard to see being under the SG bracket.
I don't have an "S" mark though, mine has "SP", is this the one I'm looking for?
Old 03-30-2011, 09:32 PM
Yes should be. The other mark should have a T in it for top dead center.
Old 03-30-2011, 11:15 PM
Great answers Dwayne!
Old 03-31-2011, 08:55 PM
brentwd's Avatar
Well guys I got it running and it has a very hard time throttling up. I tried adjusting the carb and got nothing. It idles good, but as soon as I rev it up it stumbles badly and won't rev unless I go real slow. I think it still is not close enough. I believe I need a timing light for a single cylinder. Can anyone suggest a good one? At least the mufflers not glowing anymore
Old 04-04-2011, 07:59 PM
brentwd's Avatar
UPDATE, I bought a timing light w/a tack signal. Revved it up to 1500 and set the points. It really made it nice to have one. I will see how it does when I put on the 48" deck after I restore it. Thanks for everybody's help.
Old 07-23-2016, 11:05 AM
Tonsafun Tonsafun is offline
Default Newbie in Tenn.
So I have a Cub Cadet 149 I recently bought i was told it ran last year and the guy mowed with it .Well i find that hard to believe now since the carb just flooded out the throat and flowed like a river . I replaced the carb and it began to backfire when i finally got it started .In order to rmedy this i found this wonderful site of information called CCO . I would like to thank all of you for the information posted here and have registered as a new member .Now to get to my new problem ....after replacing the carb the coil new coil wire plug points and condencer I NOW HAVE LIFE OUT OF MY NEW OLD CUB ...BUT NOW IT IDLES A LITTLE ROUGH AND SMOKES A LITTLE BUT NOT LIKE RING SMAKE MORE LIKE EXHAUST FUMES ....HOW DO I GET PAST THIS AND ENJOY MY NEW OLD TRACTOR?
Old 07-23-2016, 11:15 AM
If it's idling rough and the exhaust smells like gas then I suspect your carb is set to rich or you have a weak spark that causes the fuel not to burn completely.
Pap's 100
Restored 108
1211 Dual Stick
1050
