Old 06-20-2009, 09:41 PM
jcrews's Avatar
jcrews jcrews is offline
CBH
This may sound crazy, but did you use the same head bolts that were in there or did you replace them with new ones? I had the same problem with my 104 and learned that bolts will stretch which happened to mine and I replaced with grade 8 bolts from Tractor Supply and they also streched even though they were brand new so I bought grade 9 bolts and they did the job.
I H Pushmower,100,104,124,1450,1650,782,982,154 LoBoy,185 LoBoy,2 Farmall A's , Farmall H, and 8 IH trucks
Old 06-20-2009, 09:47 PM
CBH's Avatar
CBH CBH is offline
Yes, I used the same bolts, torqued to a little over 25 Ft. Lbs.
Old 06-20-2009, 09:57 PM
Originally Posted by CBH View Post
Today I pulled the head and de-carboned everything, but it was actually more like soot than any carbon build up. Installed with a new head gasket, mowed for about 1/2 hour,... stopped and let it idle,... turned it off ....BANG!
If it is gas getting into a hot muffler, I'm wondering if an exhaust stack style muffler would keep it from banging. What do you think?
A different muffler isn't going to change the fact that gas is still getting in there and exploding.
This should be unnecessary. Are you guys RE-torquing the bolts as per the manual after 30 min. run time? Did you check the head for flatness and correct any warpage as necessary? I have reused head bolts all but once, when I replaced them all in a tractor because one twisted off. I have NEVER reblown a head gasket, to this day, in the past 6 years.
Old 06-20-2009, 10:10 PM
CBH's Avatar
CBH CBH is offline
There were no signs of a leaking head gasket. I torqued the bolts as the manual said.
I guess I'll just have to live with it and end my mowing sessions with a bang! :biggrin2.gif:
Old 06-21-2009, 12:35 AM
RChristensen RChristensen is offline
Inactive Member
Since I don't know all the things you have done to your tractor, have you checked the adjustment of your valves lately.
Old 06-21-2009, 07:34 AM
oldcubowner's Avatar
oldcubowner oldcubowner is offline
My model 86 did that until I slowed down the idle. I have all but elimanated my carbon build up by adding some Marvel Mystry oil to the gas every time I fill it up. Most of the cubs I have been around idle to fast from items wearing out like the throttle shaft etc etc.
Rod
Old 06-21-2009, 11:20 AM
jcrews's Avatar
Matt
I used to reuse the headbolts also but Roland told me about the bolts stretching and I compared them side by side and sure enough the bolts on the engine had gotten longer. Talk about retourqeing the head, try 5 times and they still did it. I'm not saying they all do it but this could be the problem. Grade 8 bolts on exhaust manifolds on cars and trucks do it sometimes after long term high heat exposure.Roland told me some people relace the head bolts every time the replce the head gasket.
Old 06-21-2009, 11:27 AM
jcrews's Avatar
Matt
One more determing factor for me with the bolt is that it gets very hot down here in Ga(this week average high temperature 97) and that probably plays more in to my bolts stretching than in Illinois, where the summer temperatures are generally more moderate.
Old 06-21-2009, 06:08 PM
Originally Posted by jcrews View Post
Matt
Ever been to Illinois in August? It routinely gets in the mid 90's here in
August; in fact, we have lower 90's forecast for the next 3 days, which is really unusual for June...
A 10-15 degree difference shouldn't make that much of a difference in the grand scheme of things. Oldcubowner has a good point...The idle is set too fast on most of the tractors I buy. I think they left the factory set at 1000 rpm but I've seen a lot that sit at 1300-1400. I'd check that too if you haven't already.
Old 06-21-2009, 06:42 PM
murphycc
Guest
Posts: n/a
Use studs not bolts next time you change head gaskets. There is torque loss in throughout the length of the bolt. Also saves the threads on your block.
Scott
