I do plan to do that. I plan on tearing this thing completly apart and redoing it. Im am new to all this so it may not be as nice a most others on here but Im still going to make the attempt. thanks.
You'll do fine. Some guys just are naturally good with rebuilds. I like to make sure it is mechanically sound then I worry about the looks. I wasn't sure how far you were going to go with it. Sounds like you have a good plan.. Keep us updated with everything.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
I know Im jumping way ahead of myself but what do you guys think of the vansicle federal yellow and transport yellow that they sell? is either a good match to use on my cub? the reason I ask is I have a gallon of each given to me. I thought about adding some hardener in whichever I decided to use if anyone thinks one will match? thanks.
I have been using vansickel transport yellow rattel cans on some small parts on my 122 and it is a close match to the original paint.
thanks ljones. i appreciate the info.
Thank you guys for the kind words, it's good to know that there are still people out there who appreciate quality and don't necessarily accept just anything that someone shoves across the counter to them.
HOWEVER, please know that I just sold the last three shafts I had on the shelf this past week (I didn't get to use ANY of the last batch for myself!). Tuesday I will order another stick of stainless and will start making another batch of shafts as soon as it comes in. Thank you guys for all the business, it is really great to get to be a small part of so many repairs, restorations and customizing jobs! Mark
ok guys I officially have this 100 completly apart. I mean every thing. here is a better look at the clutch. I think the spring is bad.....what do you think? lol.
Also I ended up cutting the axle pin on each side with a sawzall to get it out. The remainder of the pin is really stuck in the axle good. you can see it in the pic. whats the best way to get this out? (without damaging the axle) thanks. |
Yeah, your spring looks like someone has gotten ALL the use out of it that they're going to.
Chances are, when you take the clutch apart you will find that the shaft is badly worn, the throw out bearing will probably also be bad... It's sad that so many parts on a clutch/drive shaft need to be replaced to make it work properly, but the shaft drive is one of the things that sets our Cubs apart from everything else. Once you get it rebuilt you will realize that it is SOOO worth the cost. Good luck with your 100, it is a true classic.
Ok guys I need to get back on this thing. On the clutch lever that goes on the shaft. Is the hole in it suppose to be a perfect circle? Does anyone have a picture of one so I can compare? Thanks
