Old 06-01-2009, 10:54 AM
RPalmer's Avatar
RPalmer RPalmer is offline
Originally Posted by drysumpjet View Post
But many are tempted to slow the engines way below that spec, just for the "cool" factor. The heavy flywheel on a K series single will allow for that.
That is called lugging your engine and a great way to break your crank.
Old 06-08-2012, 09:51 AM
Locrian Locrian is offline
My Dad added an extra brace to the cradle on his 1450.
This tractor is used only to work ground (plow-till-cultivate).
I know this was an old post, and hate to bump this but do you know the radius your father used to roll that secondary bar? I like the looks of that as far as rigidity much better. My problem is I'll have to have it fabricated as I don't have the tools for it, then have a friend weld it in.
Thanks in advance.
Old 06-08-2012, 04:20 PM
Merk Merk is offline
Dad started to bend the metal until he ended with is in the picture.
Old 06-08-2012, 06:43 PM
Thanks in advance.
With a 3 foot length of that size steel, you could bend it with your hands!!
Give it a try, that small of steel is very easy to bend with that large of radius.
Bend the 3 foot piece, then cut out what you need out of the center.
Old 06-09-2012, 07:26 AM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
I bought this for a tach. http://www.meter-depot.com/img/Tach_04.jpg
