Go Back   Only Cub Cadets > Off Topic > Gardens, Lawns and Landscapes
Old 03-06-2011, 12:31 PM
william1041200's Avatar
Thats a really good idea! Im thinking of putting that on a plug aerator instead. Anyone have any thoughts ? Im intending to aerate and seed same time.
Old 03-06-2011, 05:48 PM
Merk Merk is offline
Viking Landscaper:
Good luck finding one.
I prefer a broadcast spreader over a drop spreader. I get a better dristribution of seed/fertilizer with a broadcast spreader.
Old 06-09-2013, 03:29 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
I know this is an old thread, but figured I'd add my $0.02. I had the Agri-Fab 175 drop spreader & aerator combo. I ended up getting rid of it due to the fertilizer I usually use kept plugging up the holes on the bottom and having to stop and lift it up to go over things, such as the driveway, curbs, etc. Had to get off the tractor to push the lever to lower the wheels. It did, however, work well with the Scott's brand fertilizer. My off-brand fert had slightly bigger granules it appeared. The weight of the fertilizer really shoved the aerator tines into the ground; even hard packed ground. Went back to my walk behind/pull behind broadcast spreader.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 06-09-2013, 07:22 PM
I use a Montgomery Ward broadcast spreader from the 50's or 60's. It doesn't rust, except for the spoke wheels (hard rubber tires) and it will spread salt or seed without any problem at all since it's drop hole is wide and easily adjustable.
Old 06-10-2013, 12:58 AM
Is that the same model that northern tool sells for around $200? I need to overseed my entire yard and have been considering buying one for that purpose.
Did you ever try to use it for grass seed or just fertilizer?
Old 07-17-2013, 12:53 AM
I've been doing food plots for 25 years and you DO NOT want to use a pull behind broadcast spreader for seeding anything other than grain seed, oats, wheat, rye. They are way to hard to regulate the seed flow for small seed, IE clover, alfalfa, or brassisa, which is the main plants planted in the food plot world, you'll have it way to thick and the plants will be crowding themselves, and will be robbing nutrients from one another that will leave the plant stunted.
Get yourself a Earthway over the shoulder seeder. Keep the broadcast spreader for fertilizer, not seed.
