If you can't position the lines away from the tank, I would think that if they are touching and not rubbing, I see no problem.
Seems to me that the tank & valve are reasonably securely mounted. Now if they are rubbing on the engine I can see a possible problem as it does move/vibrate some. IIRR those elbows are o ring type and can be turned without any problem to position things as best as can be done. If the hard metal lines are rubbing, they can be custom bent to fit also. |
I have a 1812 and the don't rub but it is all factory.
