Old 12-04-2010, 07:02 PM
TEET's Avatar
TEET TEET is offline
Ive seen people use hose clamps arount the top of the casting too....Ive had luck without using anything..you might try dry fitting it before drilling holes into it to see if screws or rivets are really necassary......
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 12-04-2010, 10:10 PM
thenrie's Avatar
thenrie thenrie is offline
I had the same problem. I cleaned everything up very well, sanded and primered the tube, painted it, then tapped it back into place with a block of wood and a hammer (after I rebuilt the insides of the box, of course). Apparently the couple of layers of paint on the tube were enough to tighten the tolerances. My tube is solid now.
I would hesitate to use something like JB Weld on it. There may come a time you want to disassemble it. If you have to reinforce it, I'd go with Matt's suggestion of pop-rivets. Not a "stock" look, but it would work and it could be undone, if necessary.
Tony
Stafford, VA
1650, 682...
Old 12-04-2010, 11:22 PM
dieseldan123's Avatar
@Therie, the JB was suggested to me by my grandfather as a possiblity (being that he lives in Illinois and i live in TN and isnt able to see it), but i wanted everyones opinion to see what would work the best. the paint im using (rattle can) is pretty thick so im more than certain ill get a nice tight seal when it all goes back together.:biggrin2.gif:
@Jeff, i agree i want to refrain from drilling any holes unless necessary and clamps would make me feel like i had left it unfinished.
Thanks for the advice guys! ill keep you all posted!
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 12-04-2010, 11:28 PM
TEET's Avatar
Good luck....not that you'll need it :biggrin2.gif:
You will love the way your cub steers after rebuilding it...it will feel like a new tractor!
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 12-05-2010, 12:17 AM
Lol the whole thing will be a new tractor! im kinda goin for a working resto. looks great but will do the work. been at it for three months now. hopefully i can finish it close to xmas and play in the snow! (if we get any here in Nashville)
