Thanks George. Good advise there. The block cleaned up well. I guess I should dump the oil and replace before I start the motor?
Jay, one tip I have used and had good success is to use Permatex Copper Coat spray on the head gasket prior to installation. It helps seal off any imperfections that may cause a leak in the future. Two thin coats is all you need. On the down side, it is kinda pricey, but it works.
Here is the correct torque pattern and intructions for cheacking the heads flatness.
Make sure when you start reassembling the head bolts that you put a small squit of vegtable oil on the threads. Then torque in sequence. Seems to hold torque a lot better.
Ok, grabbed a piece of glass off a table at home, Shhhhhhhh! dont tell the wife, and got the recomended sand paper as per MattG, thanks Matt!!!!!
![]() Yay, finally after a few sheets and some sore arms, it was all nice and even. It had some high spots and where it started leaking it was off in that area. So I cleaned the threads up and put the new gasket on, mounted Mr. Straight Head. I bought new Grade 8 bolts and new grade 8 nuts for the studs.....I was just too lazy to wire wheel everything he he. Here she is. ![]() ![]() ![]() Well here is the funny !!!! As I go get my torque wernch out, I dont have a 9/16 deep socket to fit it ha ha doh !!!!! |
That's funny, yesterday I ran into the same issue, needed a deep 3/4" socket so I had to run out and buy one:biggrin2.gif:
glad i am not the only one !!!! ha ha
That is why I do not call myself a "MECHANIC".
They own tools for every job!!! ![]() Looks like a nice job on the resurface there JaysNJcub127!!!!! |
it happened to me too. the 9/16 deep socket... keep accumulating things in addition to the cubs!
