Old 11-08-2010, 10:44 PM
angry1 angry1 is offline
Thanks for the information
Old 11-08-2010, 10:48 PM
A voltmeter can simply be wired across the battery terminals.
Old 11-08-2010, 11:16 PM
johncub7172's Avatar
Thanks Matt and R.Bedell for the info. So I guess it is safe to say that a amp.gauge is wired the same as a voltmeter.
Old 11-08-2010, 11:23 PM
No...you are measuring two different things that cannot be measured in the same way. If you hook up the voltmeter like you would an ammeter, you will read essentially zero voltage. If you were to hook up the ammeter across the battery, you would probably either short the battery out or melt the ammeter, or both. To measure current, the ammeter has to be in series with the circuit, and to measure voltage, the voltmeter must be in parallel with whatever you are trying to measure the voltage across.
Old 12-05-2010, 05:21 AM
Thanks again guys!
Old 12-05-2010, 08:30 AM
5 Cub Cadets 5 Cub Cadets is offline
Smile
From my old electricity days, an ammeter has low resistance, so you have to break the circuit (or take out a small piece of wire, which has low resistance) and complete the circuit with the ammeter (observing polarity) and current can now flow through the meter. In comparison, the voltmeter has high resistance (higher the better), so the voltmeter is placed across a device or battery, (observing polarity). Most times, if you incorrectly hook up a voltmeter, the circuit dosen't work or you get another chance to make the correct connections, in contrast an incorrect hook up of an ammeter, damages the meter, battery or device (not too forgiving)!
