Old 11-03-2010, 07:48 PM
That might be a sticky exhaust valve, which can be caused by overheating. Is the carb and timing set correctly, and are all of the cooling fins, flywheel screen, and area under the flywheel shroud clean? I'd check all of that stuff and start using Marvel Mystery Oil in the gas.
A 109 is not 'underpowered' in my opinion. That 'bogging down' you describe may be caused by either improper carb settings or timing, as well.
Old 11-04-2010, 09:28 AM
Just looking at the carb doesn't mean it's clean. There are jets and passages that can only be cleaned by taking it apart and rebuilding it.
Old 11-04-2010, 09:47 AM
Mlamar Mlamar is offline
Default Carb
I just pulled what I would call a "new looking" carb off one of my Originals. Clean and shiny. When I opened it up to rebuild (which I do on every job) I was shocked at the gunk inside. Yes, a carb rebuilt is worth the time and $ in my opinion.
