I don't remember seeing anything over + .020 offered from Kohler. The fact that the cylinders are available individually, they figure if they don't clean up @ .020 just replace the jug with a new one. If you are lucky, your cylinders will be in spec. and just need replacement of Std. Rings. Only a teardown will tell you which way you need to go, and if other things may need attention like connecting rods, valves etc. |
The only problem with boring a KT/Mag is that the pistons are crazy expensive. I think they are around $155 each. I would almost bet you could have it resleeved cheaper.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
I am pretty sure you can get a rebuild kit,including pistons, for the mag 18 for right around $200. For some reason the kits for the kt's are near twice as much.
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
The first that needs done is diassemble the motor to see what needs done. Odds are the pistons are going to show some wear and/or marks. The area by to the exhaust valve on the piston will have some burnt/melting of the piston. The governor gear (if it is a plastic one) should be replace when the motor is apart. I would replace the crank seals while the motor is apart too. The connectig rods are must replace when you rebuild a motor. The crank journal(s) need measured to make sure they are in spec. Get a Kohler manual if you have a manual. A copy can be downloaded from the OCC's technical section or from Kohler. The manual will show you the correct way to measure cylinder wall and crank journals. You should use a micrometer, bore gage or both to measure the cylinder wall and crank journals. If you don't have access to the gages take the cylinders a good automotive machine shop and let them measure them. Odds are the cylinder(s) will be close to or out of spec. I have the automotive machine shop do the machine work. In the long run you will better off letting them do the work. I have been a machinist for more than 30 years and rebuilding small motors close to 40 years. I let the automotive machine shop do the machine work. The shop I use has a cylinder boring machine. Most motors will not last very long very long until it starts to smoke and use oil again by just honing the cylinder(s) and a set of rings from e-pay. E-bay is the last place I would buy rings from. I've heard stories of buyers getting the wrong part(s) and having a hard time getting the right parts from seller. It is your choice.....The way I do a motor cost more-it will last longer and make more power. I had someone who want just a hone and new rings. Less than 2 years later the motor had to be rebuild again. This time it was done right. |
Got a link? I've never seen any aftermarket pistons for the Magnum twins...
Here is the link, And I never said they were aftermarket ! http://www.psep.biz/store/kohler_rebuild_kits.htm Also here at the bottom of page 6 - top page 7 . From std to + .030 , under $100 per cylinder. http://www.kohler-engine-parts.opeen...&cPath=171_103
Wow!
![]() I've got that bookmarked now... |
Does the Govenor gear brake or what?
From what I've read from other members yes and they also need to be pinned at rebuild which they are not from the factory I would also like more details on this! What kind of hours can one expect to get out of a factory m18 with moderate use before the governer flys apart
