Old 10-08-2010, 07:11 AM
Wire wound resistors can be had with tolerances of 1%, 2%, and 5%. Wattage starts at 1W and can go to 500W. Wire is usually made of a high-resistivity alloy, such as nickel-chrome.
Old 10-08-2010, 08:53 PM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
That resistor probably sets the voltage at which it quits charging, or limits the current.
I sure hope an exploded battery isn't your first hint that you should have bought a new regulator...
You might be able to take the reg to a generator shop. If they say it can't be done, I'd believe them. Then again, they might be able to fix it right.
Jim in Lafayette, CO
Cub Cadet 122, 126
Old 10-08-2010, 08:59 PM
TheSaturnV's Avatar
I picked up a new one today at CarQuest. Chalk it up to a $61 mistake. Thanks Roland for all the technical info, interesting stuff.
Old 10-10-2010, 08:21 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
Originally Posted by pulse301 View Post
Are there not any markings on there that tell you the specs of it? I always remember looking at a chart for color codes on ones I used on my "learn to solder" kits that i had as a kid. If there are any markings on it you might be able to use it to just replace the resistor itself.
All resistors are color coded. With the age of older resistors, I doubt any resemblance of a color would be left, so you're best off taking a good working VR, and taking some readings....but you'll probably have to seperate it at one end to get a true reading.
Fly Fishing is not a sport...It's a way of life.
Old 10-10-2010, 08:45 PM
All carbon core resistors are color coded. I have seen many wire wound resistor with no color codes but with the actual rating stenciled on them. I would venture an educated guess, that Delco did NOT mark those resistors so they could end up selling you a new V/R when the resistor broke. Trade secret ya know....:biggrin2.gif:
