Old 09-25-2010, 09:57 PM
Okay ,Matt you are right there are 2 different sized S/G
I have found a cw s/g
Easton ct.how do you flip it ?
Old 09-25-2010, 10:37 PM
Technically, you can not put the shaft through from the other side... There are no brushes/holders on the other end and the shoes would not line up with the armature.
Old 09-26-2010, 09:54 AM
eastonct124's Avatar
eastonct124 eastonct124 is offline
That's what I mean by "technically".
I've done it with either a 110 motor, and/or an automotive starter. I remember telling my friend he was sol and then he did it and it worked.....I was surprised, and sure enough it works. But again, all depends on the starter.
Fly Fishing is not a sport...It's a way of life.
Old 09-27-2010, 01:26 AM
hillbilly hillbilly is offline
I am pretty sure you can wire a negative ground tractor, positive ground and everything will function correctly except!! the voltage regulator will be fried near instantaniously. Seen this happen on large tractors a few times. Starters spin correctly ignition functions, doesn't charge.
Old 01-03-2011, 09:10 AM
cub123's Avatar
cub123 cub123 is offline
The direction can be changed,i have had it done,if fact the starter on my 123 is from a sears suburban.I did not do the work,but the guy who did changed the direction,and rebuilt it for about $60.The cubs are a bit odd,because most of the time it is normal to have the s/g on the flywheel side,but because when IH put the gear reduction on the Cub transmission they had to put the engine in backwards.
