Old 02-14-2026, 01:41 PM
Thumbs up
Dittos on that!!
Old 02-14-2026, 10:12 PM
Billy-O's Avatar
Billy-O Billy-O is offline
That K241 is kinda sorry looking at first glance.... I with the others doing proper rebuild on your original motor.
Plow blade
#2 Cart
QA36 snowthower
Old 02-15-2026, 06:19 PM
docmirror's Avatar
docmirror docmirror is offline
Whelp, if it's gonna be a 50 hour job to convert, I woulda rebuilt mine. I got the engine for almost nothing, and it was only 13 miles away. The labor to R&R the engine is basically the same to rebuilt or swap in this, so if I can put a 10HP in there, and it will run(it has compression), then my R&R time just got more valuable.
Suppose my crank is trash? Suppose my cyl is damaged? Suppose my cam is flattened? Everything is relative, so I ask; "is it a drop-in repl"?
Right now, it's looking like there are very few mods/upgrades/changes to get the 10HP pushing, and I have less to worry about this summer when the grass gets high again. It was working pretty hard with just the 7.
Old 02-16-2026, 07:17 AM
ironman's Avatar
ironman ironman is offline
It seems to me that no matter what route you choose to go,
the first step involved is removal of the seized engine from the tractor.
So why wouldn't you take that first step, and then you can place the two engines
side by side and the answer to your question will be right in front of you.
Old 02-16-2026, 09:34 AM
Guess you won't know until you dismantle it.
Old 02-16-2026, 09:48 AM
I would remove the old and clean the carb, new points, plug, and condenser. What ever else needs done to the K241 to get it running. Stick it on the "O" The wiring to the motor is the same as the 8hp
Old 02-17-2026, 12:21 AM
docmirror's Avatar
I pulled the K161 from the Original. The engine mounts are the same pattern.
And, I come here for assistance just any other CC owner. In a few weeks, I'll be able to answer the question; 'K241 drop in fit to Original', and what is needed.
