Old 12-12-2025, 05:24 PM
Sergeant's Avatar
Sergeant Sergeant is offline
Originally Posted by CubDieselFan View Post
Wow, that is a lot of hours in a short amount of time. How many acres does mow with it?
22 1/2 acre to 3/4 acre Yards, Plus snow removal for about 25 In the subdivision he lives in
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
Old 12-13-2025, 07:41 PM
CubbaCudet CubbaCudet is offline
Originally Posted by Sergeant View Post
Not really. My friend's 2017 XT2 GX 54D has over 3000 hours with a Kohler engine. The only engine issue he had was an oil drain, which Kohler updated and fixed through a recall, and the current Kohlers have the corrected oil drain.
If You want a Kawasaki version You can get it here https://www.craftsman.com/en-us/prod...ing-lawn-mower either at an Ace Hardware or a Lowes store
I never knew that those two models were basically the same!
It's an open ended question with no perfect answer, but do you have any thoughts as to which one, based on what tends to break on these things (cub cadet vs craftsman) is 'easier' to fix and/or which tends to break less often?
You only need two things in life: duct tape and WD-40.
If it's loose and supposed to be stuck, use duct tape.
If it's stuck and needs to be loose, use WD-40.
Old 12-14-2025, 02:26 AM
Sergeant's Avatar
Attachment 117506
Attachment 117507
That I can't answer because, except for the engine, front axle, and paint color, they are the same tractor. With the XT2 GX54D, you get easier dealer support. With the Craftsman, you get a Kawasaki and a much tighter turn radius. And both have the same parent company, Stanley/MTD.
Old 12-14-2025, 08:50 AM
ironman's Avatar
ironman ironman is offline
Or.....
you could base your choice on winning colors...
Tags
new cub, pto, xt2
