I got the one with the Tecumseh running, although not running great yet. It just needed the carb cleaned, and the points sanded, and I changed the oil. I ordered a Chinese carb for it, since I got that and an air cleaner for about the same as just a carb kit would have cost. I figured I would just use the parts form that to rebuild the original carb. I tried putting that new one on first, but I can’t get it to run right. I’ve never had much luck with the cheap carbs on anything, so I wasn’t really expecting much. I have the original carb cleaned, I just have to swap the parts over and put it back on.
I did get it on my 149. As I said earlier, I didn’t get the mounting brackets with them. The bagger frame slides over the rear axle tubes, and I just cut a piece of angle iron to bolt between the tractor hitch and the frame of the bagger. It seems to be holding it solid enough. The PO of this tractor welded an extra bracket onto the hitch, which is actually helping as well. The bagger frame slides right under it. I would still like to find a correct set of mounts, but I think this will work fine for now. Even though it wasn’t running great, I had to try it out. It seems to work alright, but I only ran it long enough to fill the bag once. I’ll get the original carb back on, and hopefully I can use it more this weekend. My only complaint so far is that it’s loud! I can’t even hear the tractor engine over it. I can’t say yet if it’s much better than my 1440 with a non powered bagger. That works ok too, but it does block up easy if the leaves are wet, or if I go to fast.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
