Old 08-10-2024, 02:18 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Pump is back in , works fine with no leaks now, but the large hose size in relation to the mounting neck took a fair amount of compression on those clamps. They were OEM clamps and took more torque than any of the modern Chinesium or American types.
I did remove the battery box, which helped provide some working room. I think if I were to do this again, I'd install studs in the aluminum block rather than risk pulling or cross threading the bolts it was assembled with. I did make sure that the bolt threads were clean, and I used anti-seize on them.
Yeah, it's dirty, but it works for a living (I clean it when I put it away in the fall, and before I use it in the spring). Heat index here is 102 and we just had a tropical storm come through, so it was sweaty work with saturation level humidity .
Thanks to Cub Cadet Specialties for the help with hoses.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 08-19-2024, 02:10 AM
TheSaturnV's Avatar
Thanks for the updates, nice work. We should be blessed with spare parts for the D600 for quite a few years to come, since they put them all over the world including the high seas. I used to buy parts for mine from a sailboat website because they had better prices.
