Old 08-08-2009, 05:04 PM
IROCKWITHDIRT's Avatar
IROCKWITHDIRT IROCKWITHDIRT is offline
Digging up an old post for one reason. Checked my bearings, they measure 1.378.
Shopping, I found 2 STENS numbers.
Part No. 215-210
OD:1.378 "
Height:0.495 "
With open back race for grease penetration
AND:
Part No. 215-079
OD:1.375 "
Height:0.527 "
Heavy-duty
Both are listed as 3/4" X 1 3/8" and as a replacement for CUB CADET-384881R93.
Old 08-25-2009, 09:23 PM
redwaycc's Avatar
redwaycc redwaycc is offline
hi, I am new to the group and came down with yellow fever after my MTD "yard-machine" tiller took a dump and forced me to find something better.
So, I was reading this post because I was in the process of replacing the front wheel bearings on my cc 100 and was looking for some useful information and part numbers. The original bearings that I pulled from the hubs are HEIM RF 122214 AP and those are what I ordered as replacements. They arrived today and I installed the bearings in the right wheel, mounted the wheel on the spindle, and everything was good as new. I then did the same for the left wheel and the amount of play is only slightly better than before.
I removed the wheel nut and washer and noticed that the spindle was protruding beyond the wheel bearing by approx 0.060". Before I reached for the power grinder to fix that, I swapped left and right wheels and the problem followed to the right side. I measured the spindle lengths and both are approx. 3.075" and match in length of a set I got off ebay.
I am wondering if this was the problem of the original post by JMD and/or has anyone else has seen this difference in hub widths?
rc
100(2) 128, 129, 76(1/2)
