Old 12-07-2023, 10:06 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
The manual doesn’t include the part the drives the deck Ironman. It just includes the bare motor from Kohler. Would that be the mule drive? Or PTO? Or what? Thanks anyways as it’ll be helpful in the near future of the rebuild. How do I remove the end of the motor shown in the picture. Not knowing what I was doing, I originally tried turning out the 3 screws, but they just spin and I don’t even know what removing them would do. Then I found Allen head screws/bolts in the holes that I circled in red. However, I sprayed them a couple times in a 24 hour period and they are still stuck… So basically I need help with removing this end of the motor that runs the belts/deck.
https://www.onlycubcadets.net/forum/...pictureid=8391
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 12-08-2023, 08:46 AM
The Allen head screws you refer to will need to be super clean so
your wrench fits perfectly. After your soaking you will find there are
2 set screws in each whole, these hold the PTO to the bearing. Once
you get the PTO off you will see the set screws for the bearing and
the pulley. All this will take quite a bit of tapping and such to get off.
THis manual actually does a pretty good job of describing this procedure.
https://s3.us-east-2.amazonaws.com/c...ervice+Man.pdf
Ken
Old 12-08-2023, 09:20 AM
LAWN BOY's Avatar
Thanks. That manual does do a good job of explaining. I’ll have to clean the set screws more and I do have a 3 jaw puller.
Old 12-08-2023, 09:54 AM
jbrewer's Avatar
jbrewer jbrewer is offline
There comes a time for all of us, to Read The Fine Manual.
You've got some knowledgeable coaches but you'll likely not need them as much after a quick trip to the documentation
It would be great if you could post some pics along the way. I'll be heading into this project pretty soon myself.
How's it going?
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-08-2023, 09:59 AM
jbrewer's Avatar
What you're working on is the PTO assembly at the moment.
Those set screws can be tough to get out. Use a high quality US made allen wrench. One thing I've done that has been helpful, is to get a long thin punch that will fit IN the bottom of the hex recess (not touching the flat sides) and give it a good whack or two , in order to loosen the interface between the housing and the allen screws. Then follow with some Kroil or PBlaster
This has worked for me. As others have pointed out, there should be TWO Hex screws in there, so you'll get good at this.
Above all, don't twist off the flats or snap a wrench in the set screw. Impact and penetrating fluid have always done it for me (and above all, patience!)
You got this. It will just take some patience (and quality hex tools!)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 12-08-2023, 10:36 AM
ironman's Avatar
ironman ironman is offline
Reminiscent of years past, after the kids were in bed and too much mind expanding Christmas Eve ,
I would attempt to assemble their gifts without reading the assembly instructions (who needs them?).
Then in the , I'd read the instructions and do it again.
Old 12-18-2023, 08:54 PM
LAWN BOY's Avatar
Got the piston out and 3 of the set screws from the PTO clutch. The screw that’s in the hole that I circled in red is soaking in PBlaster.
https://www.onlycubcadets.net/forum/...pictureid=8392
Old 12-19-2023, 09:05 PM
LAWN BOY's Avatar
I now have all 6 set screws out, but this last one that I circled the hole for in red is still tight. Sprayed with PBlaster last night and now again.
https://www.onlycubcadets.net/forum/...pictureid=8393
Old 12-20-2023, 07:56 AM
ironman's Avatar
If the six set screws you have out are all out of the PTO clutch
(there should be three pointed ones and three flat ones)
then the PTO clutch should pull off. There is nothing else left holding
it on except probably rust. Then you will have better access to the
set screws (two of them) holding the basket pulley on as seen above in
West Valley G's pic shown in post #12.
Old 12-21-2023, 11:36 AM
LAWN BOY's Avatar
Got the PTO clutch off. Will do basket pulley tonight if I have time.
