Old 08-12-2023, 03:39 PM
Done it about 200+ times the gauge does not hit the button. would you like a picture?
Old 08-12-2023, 04:27 PM
ironman's Avatar
ironman ironman is offline
Yes, that would be kind of you. Thanks in advance.
Old 08-12-2023, 05:03 PM
jcubtroy's Avatar
jcubtroy jcubtroy is offline
Darkminion 17 is spot on. I,ve personally done 50 to 60 who counts. after 50 some years getting the PTO screws out & off the bearing is always a miracle in the making.
Old 08-12-2023, 05:58 PM
Here you go, those two pointy thingies leave scratches on the spring and sounds like a little birdie when you wiggle it side to side so you know it is touching it, none if you made it too tight. Also using the right gauge helps also.
Old 08-13-2023, 02:18 PM
ironman's Avatar
I misunderstood what you meant when you previously said "rest on the spring". Thanks for explaining
