Old 05-08-2023, 06:11 AM
Originally Posted by Gompers View Post
No, 3240 has single inboard brake. This model only fits the very early cast AL transmissions with dual disk brakes. 98 and maybe 99 model years.
True but I believe Fins saw it on the parts look-up. They show that kit on several models that I don't think it will fit on.
Old 05-08-2023, 02:22 PM
Sergeant's Avatar
Sergeant Sergeant is offline
If the Break controls our outside the Frame, The 190-365-100 will fit. The reason for the redesign to 190-207-100 was the Break control being put on the Inside of the Frame would infer with placement of the Hydraulic Lift cylinder. But the 190-207-100 will fit all models of the 3000 series produced. That was the only nice thing about the later 190-207-100.
What is funny about the 190-365-100 is, MTD Made a Lot more spare Parts for that 3 point kit than they did for the Later 190-207-100.
But the 190-365-100 was originally made for the aluminum Transmission cases
I prefer the rocker shaft from the 190-365-100 as the Brackets for Mounting the rocker shaft to rear hitch are not separate from the rocker-shaft I had finsruskw Fabricate the Rocker shaft Brackets for the 190-207-100 rocker shaft and a New rear Hitch Plate for the 190-207-100 3 point kit Thanks to the help Oak & Other Members here.
The 190-365-100 is a Much simpler design for the 3 point hitch compared to the 190-207-100
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
