Old 02-08-2023, 03:34 PM
farmer52 farmer52 is offline
FYI, there is a baffle in the tank so the marbles/nuts/stones will not clean that area.
Ken
Old fart - new to Cub Cadets
Looking for a nice original low hour 1772 or 1782
Old 02-09-2023, 09:11 AM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Thanks for the advice everyone. The only thing I’m not understanding is how to use MMO after I weld and how much will I have to use?
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 02-09-2023, 10:20 AM
Are you welding the broken bracket that holds the tank on? No need for mmo, remove it and repair.
Old 02-09-2023, 11:10 AM
LAWN BOY's Avatar
Default Response to Darkminion
I also need to clean the gas tank DarkMinion.
Old 02-09-2023, 02:13 PM
jcubtroy's Avatar
jcubtroy jcubtroy is offline
Lawn boy, If you do the vinegar way or weld, put some kinda oil in tank to coat it. Not a lot, just sloosh it around and drain. I use MMO for numerous tasks, so I always have some.
Old 02-09-2023, 02:30 PM
LAWN BOY's Avatar
Default Clarification
So I fill with vinegar, let sit a couple days.
Add hex nuts, slosh around.
Drain, wash with Dawn and warm water.
After rinsing, slosh around MMO in it.
Do my welding last because I have to drive up north to do the welding with a relative. I am still learning how to weld and I found out that my neighbor’s welder no longer works.
Old 02-10-2023, 07:53 PM
BKsCC BKsCC is offline
There's this stuff called Evap-O-Rust that's about $25-$30 for a gallon at tractor supply. It's really good stuff and works better and faster than vinegar, and won't accidentally discolor metal red from sitting too long (It'll darken metal though if it sits for over 24 hours). I just used it to do my tank. It's reusable for several uses so don't just dump it away when you're done. Run it through some cheesecloth to catch the chunks of rust and then re-bottle it.
Old 02-13-2023, 09:00 AM
LAWN BOY's Avatar
Default EvapOrust
I’ll pick some up.
Old 02-13-2023, 10:16 AM
jcubtroy's Avatar
sounds like your puttting a system to get the job done!!!!!
Old 02-13-2023, 11:21 AM
LAWN BOY's Avatar
That’s what it’s turning into I guess, Lol.
