![]() Quote:
My manual says the double pulley should be greased twice yearly or every 50 hours, although I haven't spotted the fitting (I haven't looked since reading that). Replacing the pulley and bearing would be about $125, which I'd like to avoid but could stomach if i was absolutely sure it would fix the problem. Most of that cost is pulley, so maybe mine is salvageable. The fitting I greased was the idler arm assembly. Is that supposed to ooze grease out the top when its full? I have now looked and can find no grease fitting on the double pulley
Cub Cadet 2166 |
Mine doesn’t have a grease fitting on the double pulley either, only on the blade pulleys. Unless they mean just to remove the pulley and grease the shaft?
![]() Quote:
So my choice is to fix this one, fix my 108, or let the lawn overtake the house. I don't think I want to fix the 108 so that leaves 2 choices which I'm still mulling over.
Cub Cadet 2166 |
If you’re gonna replace the spindle bearings do both sides together. I tried only replacing one (since the other seemed fine) and still had bad vibration/noise. Replaced the other and now it’s fine.
Some of the double pulleys have grease fittings and some don't. I use a needle adapter to grease the sealed bearings in those that don't have a fitting. I've also found that the bearings are a very loose fit in the double pulley.
How would I know if the bearings are all that's bad? Would I just be looking for wear in the raceway or? I've been lucky and never had a bad bearing or spindle on my 108 in almost 20 years.
Cub Cadet 2166 |
![]() Quote:
Cub Cadet 2166 |
That’s what I mean. The bearings inside the spindles can be replaced without replacing the entire spindle.
But I’d shop around. Mine shipped with two 42” deck models - one you could gets entire spindles (with bearings already installed) for $30-40 each on eBay, but I just happened to have the one where spindles are $130 EACH so it was cheaper to just replace the bearings. |
![]() Quote:
If only I could find the double pulley for that price, or less.
Cub Cadet 2166 |
Looks like the 2166 only had one deck model so that’s good the spindles are cheap. As I said mine had two different decks and I just happened to get the one with expensive spindles
