If I got all that would I be asking what that bracket was? Everyone on this forum seems to have some smart attitude.
Every now and again it gets a little snarky in here, but a better bunch of IH Cub guys you will not find. First you'll need to remove that tiller bracket and you can probably get a few bucks out of it on ebay. Keep in mind where it is bolted through that bracket, that the bolts are longer. You may want to get more hardware the same size as the 3 above that bracket.
The fitting you are after is called the draw bar, and it is a simple 90 degree bracket with a hole for bolting up a trailer ball or for pinning implements to the back like wagons. I'd suggest while you are doing this work that you go ahead and do a fluid change, clean the gunk out of the bottom of the case, install a new filter (not automotive) and button it all back up with a new gasket. |
You mean this one?
Yes, it will fit. |
Yes that one.
One other thing. Willna sleeve hitch fit without removing the tiller bracket? Also saw a pic of a Cub and his drawbar was bolted to the rear of that tiller plate. |
