Old 07-12-2021, 12:08 PM
I'm thinking the problem is the turbo encabulator connection explained here:
https://www.youtube.com/watch?v=Ac7G7xOG2Ag
Old 08-02-2021, 06:29 PM
littletractor littletractor is offline
Got the transmission working, pulled shift lever, got the gears loose, put back together, worked for a week and hung up again. Have done all of this 3 times and will eventually hang up in gear again. Help, any ideas.
Old 08-12-2021, 07:29 AM
cooperino's Avatar
#18 in Ironmans photo. The clamps are probably broken or loose not keeping tension on the fork rods
Old 08-27-2021, 03:42 PM
Finbar Finbar is offline
Hi folks, new member here. I just went through this on a 122 my wife inherited. Stuck in reverse. So after seeing this thread i pulled the body work and shifter plate and voila reverse shifter fork bolt had worked loose. Got it back to neutral and tightened the bolt, replaced the sheet metal and all is good again. Thanks to the knowledgeable members of this board it was a painless repair!
