bugeye,
i appreciate the input, I doubt that the fluid has ever been changed in it, this thing is like a tank, it just keeps working till this past week. I have the Service Manual and the Owner's Manual for the 1811, but input from long time owner's experience is not always covered in a manual and is a great help. I'm adding everyone's input into a page to attach into the service manual thanks for sharing your experience and knowledge! |
CubDieselFan,
I doubt that the fluid ever been changed. I have the gasket and filter. I have to get Hytran. thanks for the input! |
IHcubCadet147,
good to hear, I hope that all mine needs. I'llpost an update once I service it. Regards, OKcubfan (Chuck) |
That made me laugh, I borrowed my neighbor's bull one time to service my heffers.
ol'George,
glad I could put a smile on your face. Let's keep that just on OCC, in some states that could be illegal ![]() |
I'll take that under advisement, and duly noted.
No more humor or assimilating livestock terms, got it! Good luck with your "service" procedure. |
Again, thanks to everyone for sharing their knowledge and experience.
Apologies for this lste entry, but I thought i should post the actual fix on my 1811 issue (no max speed, transmission vibration and noise when moving hydro control forward.) I did change the filter and fluid. BUT the real culprit was the front flex coupling was missing a good amount of material (read as chewed on by a rodent) which caused the need to replace the Self-Aligning Ball Bushing (PN 941-3004) Dad's 1811 runs like a dream again. |
Thanks for the update.
I'm working on a 1210 and a 582 right now. both are getting new flex couplers and ball bushings. I'm making a new driveshaft for the 1210 and once the 582 is apart I will know if I need to make one for it also. |
![]() Quote:
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Tags |
1811; hydro issue |
