Old 05-22-2021, 07:41 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Originally Posted by Imnaykid View Post
Again, Thanks.
On the CC-O. The valves do move up and down and the piston does not. Mr. The Helicoil did not hold with blue or red locktight. The parts guy just said run it in, well that didn't work. Can the head be re-tapped while on the engine? I don't want to change heads now, I wanted the engine swap to be an after mowing season project
Well, your options are shrinking!
No, you can't (safely) tap the head with it still on the engine ... you're going to end up with a bunch of aluminum shavings down in the cylinder that way.
It's kind of hard to make sure of your problem. It SOUNDS like the helicoil won't stay threaded into the head because the threads for it are stripped/buggered up. If that's the case, it might be possible to buy a 2x oversize helicoil but I doubt it.
In any event, the head's gotta come off . That's a simple job UNLESS you snap off the bolt / stud that's near the exhaust port, which is always quite possible. Then you'll meet Mr Helicoil again.
Oh, and find a new Parts Guy for advice :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 05-22-2021, 09:24 PM
ironman's Avatar
ironman ironman is offline
Here ya go.....you got 6 days to procrastinate about it.
https://www.ebay.com/itm/20346473013...8AAOSw5yxgqX7a
