Old 12-17-2023, 03:16 PM
CubDieselFan's Avatar
Post a picture of the valve. My 1572 did that when I got it. The fuel filters were stopped up. Replaced both of them and that corrected the issue.
Old 12-20-2023, 01:57 PM
bleoh bleoh is offline
Unfortunately it started doing it again after a little while. The only thing I have not replaced is the valve in the tank. I figure the return one is fine so I just have the supply one and two grommets on order, should be here Saturday.
Attached is a picture of the old filter housing valve.
Old 01-04-2024, 06:43 PM
A new valve arrived and it made it worse. The old valve looked like it had signs of the screen getting sucked in so I was hopeful the new valve would work. It had a metal screen but even as I was bleeding out the system it did not seem like it was flowing good enough.
I decided that there was plenty of filtration in the system and took the screen off the old valve and cleaned out the inside with a Dremel. I figure the port and polish job is good for another .001 HP! I did not get to run it to long, but it seems to have fixed it. fingers crossed.
Old 01-04-2024, 08:55 PM
Have you cleaned out the tank? I would see what is floating around in the bottom. Debris may have been collecting around the mesh.
Old 01-06-2024, 06:10 PM
I did clean out the tank. I have had that happen to me with a BX1500. Would run great for days or weeks at a time and then suddenly stall out and have no power. The tank was clean but I decided to flush it out anyway. Found one small leaf in the tank. I figured it would float around harmlessly until it got close to the fuel line and then get sucked over it and kill the engine but would not get sucked into the line or be damaged. Then when you let the tractor sit it would float away to the other side of the tank. Maybe that leaf is why I got a good deal on the tractor from the PO....
Anyway, I was able to run the 1572 for a while this morning bringing firewood up to the house getting ready for the weather here in Maryland and it ran great. I am confident it is fixed now. Thanks!!!
