Old 07-13-2021, 08:16 PM
SLS327 SLS327 is offline
Thank you for the tips. I will get around to posting a couple pictures of the cylinder walls and advice on that, because yes I would spend the time to rebuild that and a wire harness. Yes, the 1720 is a parts unit. motor is an MV18S and hydro gear 326769.
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 07-17-2021, 02:51 PM
Default split 149
The rear transmission was loose to the frame so I split that to replace the cork gasket and replace the driveshaft. And the hydro linkage needs to be tightened up. Here are some pictures of the split tractor.
Steven
