You have to put a key inn the ignition of my car and turn it but there is still one more step involved.
Just curious... Why would you need/want a tac on a GT?? |
![]() Quote:
No turn signals, had vacuum wipers, with no washers or window defrosters. did have an am radio with 1 speaker. Had a throttle and choke knob on the dash. Good old days!! ![]() |
Keyless ignition was around in the early '60's. I had a Biscayne with a dash ignition switch and one of the positions you could turn the engine off and remove the key and not need it ever again. Of course by the time I got it the tranny and linkage was very loose. When I had the 3 in the Tree into third I had a length of dog chain on the shift lever that I wrapped under my leg to hold it in gear.
finurskw: I'll be putting a stand alone hydraulic system on the tractor to run a FEL and a tiller. I'd like to be able to monitor pump speed/output and workload for greatest efficiency. I'm not of the mindset that just running at 3,600 is the best for engine or component longevity. If I can run the tiller at 2,400, to do the same amount of work, then I'm saving fuel and wear and tear. Make sense? |
![]() Quote:
Tack: Yes no need to run full 3600 doing small chores but it is recommended for mowing as blades and cooling need WFO throttle. ![]() |
![]() Quote:
I mean, the original purpose of a car was to be faster transportation... never was supposed to have anything to do with comfort!
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
What kind/brand of loader are you contemplating?
^^^ The FEL will be completely home grown.
Like ole'George, I had a foot plunger starter that was in a 1950 GMC panel van. When the "Shagg'en Wagons" were all the rage, I had lots of people want to buy it, but it was my daily driver at the time. Stuck a twelve volt battery in it, changed the headlights and then only the ones that blew out after that. So easy when there were industry standards for most vehicles accessories. |
![]() Quote:
![]() Ya I had to laugh when they advertised push button starting on the new cars. '49-52 chevy had a pushbutton on the dash for starting, big improvement over the foot starter button. These kids today should drive a vacuum wiper vehicle up hill with no windshield defroster and roll down the window to signal a turn in rain sleet & snow conditions. Armstrong steering, no power brakes, and air conditioning was a cowl vent and windows down Ha,LOL Now back to the regular scheduled topic ![]() |
Don't remember changing any of that, though maybe I did. The heater reostat coil would glow dull orange, but it never gave out, just added more heat
Nobody mentioned re-capped snow tread tires for the winter. Some folks liked the sawdust or walnut shell compounds.
