Now that is a cool looking tractor.
Ken |
![]() Quote:
I can see why pulling power might be low, the thing is driven by a dinky little belt and 7hp engine. The tires may not help a ton with pulling, but sure will help with traction!
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
![]() Quote:
Nice score!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]() ![]() |
Help me understand timing of the blades. Not a term I am familiar
with. Hope its something particular to these tractors. Or I have been missing something like forever. Ken |
The path of the two blades overlap each other and if not timed correctly, they can collide.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Thank you guys for all the positive responses!
As mentioned, the two blades overlap. The deck has the two nominal spindles just like any mower deck. However, the belt between the two spindles uses a toothed timing belt, much like the timing belt found on many cars from the crankshaft to the cam(s). If not kept in time, the blades will strike at the overlap in the center of the deck.
It's very easy to time the blades. One blade runs longitudinal, and one blade runs horizontal, then the belt is fitted around the geared pulleys. The benefit to this is there are no 'suckers' that stick up in the center after mowing because they were missed by either the right or left blade set. I find it also helps to unload the trimmings from the opposed side of the deck where there is no chute. The trimmings hardly ever clog up under the deck, even when cutting real thick stuff. |
![]() Quote:
It really is a simple design, and easy to repair. I was able to get the bearings at Purvis, and one of the vendors supplied the spindle shaft as good used until for a couple bucks.
I would inspect the timing belt carefully, that is the 'weak link' of the system, and would cause serious harm, even injury if it goes out during high speed operation. Also, get the torque wrench on the spindle nuts, and make sure there is no play in the key and keyway. Clean, tight, then greased, and ready to go. The bearings I got were from Germany, made by SKF. I would not recommend Chinese bearings for this application. |
