Old 10-16-2020, 01:54 PM
twoton twoton is offline
Old 10-16-2020, 05:36 PM
Matt Ellerbee Matt Ellerbee is offline
Here are the pictures.
1st is the axle with bearings top and bottom, spacer was removed from previous picture.
2nd is the 7/16-20 by 7/16-20 rod ends. Had to drill out the steering C for them to fit.
3rd is where the bushings were pressed on, factory is some plastic/rubber stuff that was almost nonexistent, had just enough to get some measurements with calipers.
4th is cam gear I removed, wire brushed and greased with 3% moly. I thought about doing another roller thrust bearing, in lieu of the spacer that is near the PTO. But I really don’t think that’s needed.
