Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 07-26-2020, 08:35 AM
This is where I got mine.
https://www.amazon.com/Briggs-Stratt.../dp/B005F6P838
Two ends go to the armatures, the single end goes to a spade connector on a stud mounted on the blower housing, right side of the engine inside. Outside, another spade connector the tractor engine harness connects to.
If you don't have the engine harness connected on the outside, you can't ground the armatures to kill the engine.
Old 07-26-2020, 09:45 AM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
Thank you for link.
I found wiring schematic on-line
I know there is some on this forum
I'm still learning to navigate the site
Previous owner had yellow wire attached to fuel solenoid.
Looks like I got some wiring to trace down.
https://www.cubcadetpartsnmore.com/c...ing-schematics
Old 07-26-2020, 12:33 PM
They won't run too well like that.
Old 08-20-2020, 11:12 PM
I am one to share info.
I will try to make things clear when I have this back up to Par.
I have been tracing wires for weeks (when I have time)
I have been working a lot of hours at work.
Here is what I have found in my spare time.
I used the Wiring Diagram for 1641 that is shared on this site.
What I found was Previous owner swaped terminals in the plugs
The Ground terminal was in the switch the blue terminal was on ground to switch.
I have got only one more issue to resolve then I will fire it up.
Old 08-21-2020, 06:56 AM
Don't ya just love uncovering "cobble jobs"....???
Old 05-08-2021, 07:34 AM
Esteban Esteban is offline
Well, did you get it all straightened out ?
Old 05-08-2021, 09:51 AM
Yes
After I found the bad diode that was pinched in the engine guards
on the 1st page of this thread.
Thanks to help from Cannon51 & Mike McKown
I used the wiring diagram in the link above .
I removed the harness and reconfigured it like it's supposed to be.
The PO had moved wires around in the ignition switch
For what reason
It runs like a top now.
