Old 05-31-2020, 08:54 AM
mik125 mik125 is offline
George, makes perfect sense now. I tightened the lever this morning and it no longer slips! When I reassemble something after having it all apart and something doesnt work I always assume the worst.
With the new carb, going from wide open to idle there isnt much play before the engine breaks up. I assume thats where the adjustmenrt of the high/low on the carb comes into play which is likely my next step.
Thanks for your patience.
Old 05-31-2020, 09:41 AM
finsruskw finsruskw is online now
What did I say??
Old 05-31-2020, 10:32 AM
Indeed, you mentioned it last night and it was #1 on my to-do list this morning. Thank you, just drove it around the yard a bit and it held tight.
Old 05-31-2020, 08:34 PM
dodge trucker dodge trucker is offline
curious question, sorry it aint related to your reason for your post...
Another Illinois member here, wondering where abouts within this miserable state, that you hail from?
Old 06-02-2020, 11:05 AM
BKsCC BKsCC is offline
I'm having the exact same issue, and to boot, my Choke likes to engage itself.
I got the motor started, the throttle dances all over the place on its own, I disengage the choke, but every 30-45 seconds or so it starts to push the choke knob back out about 1/4 the way, and I have to shove it back in.
My governor must be way out of whack too because at full throttle on the lever I don't get full throttle on the carb unless I pull it on the carb by hand. When the engine is off the lever commands full range of motion though. When I rev it by hand to full it sounds like I'm wayyy over revving it.
