There is a special washer that goes on the stud called a "stat o seal".
As for the other seal, try setting it as little as possible in the bore.
I didnt see this part in the diagram parts. Can you show me?
the washer or the diagram?
You talk about number 53? I fixed that. That stopped leaking.
![]() Quote:
Redi-Sleeves Timken offers Redi-Sleeves, which are precision stainless steel wear sleeves designed to be pressed onto a shaft for an enhanced sealing surface. Redi-Sleeves are fast, inexpensive repair options for grooved or worn shafts. Design Attributes Timken’s line of Redi-Sleeves feature a strong, durable stainless-steel construction that helps create a corrosion-free sealing surface that may surpass original shaft specifications Redi-Sleeves have an ultra-thin construction of 0.25mm (0.1″) that allows the original seal size to be used with minimal additional lip loading |
![]() Quote:
Most bearing/seal suppliers can supply or likely on-line can be found ,need to mic shaft and find a suitable size sleeve for the shaft size I'm not sure how small they make them usually they are near the end of the shaft as the supplied installation tool only has a short reach. Sometimes a homemade installation driver has to be made to drive it on far enough . How bad is your shaft in the seal area? Is it pitted or worn so far under size that the seal is not making contact ? As someone said on a earlier post perhaps you can move the seal one way or another or add the second seal if not done already. A good machine shop could likely repair this shaft several different ways. One way would be to see what the next bigger ID seal with the proper OD would be and have a sleeve made to fit over the shaft with a slight interference fit and warm it up and slide it in place . As you mentioned earlier is the seal/seals in the right direction . good luck ,hope some of the posted info helps !
![]() Quote:
Yes that should be the correct installation, don't push the seals in to far as to block the drain hole as mentioned in an earlier post keep them out towards the pulley end of the fit. Here is the redi sleeve part you'd likely use but if the shaft is not pitted or undersized the redi sleeve should not be needed, is there a bushing/bearing worn that is causing excess play ? CR Seals (SKF) 99050
Thin Wall Speedi-Sleeve - 0.500 in Shaft Dia., 0.250 in Width, Stainless Steel Material |
![]() Quote:
