Old 04-04-2020, 12:32 PM
cooperino's Avatar
Originally Posted by guyton44 View Post
It shows a full discharge when running!
OK. when removing clutch, I am assuming you removed hood? and maybe front part of tractor? Do you have headlights? I think you may have moved some wiring not realizing it. How about the voltage regulator?
Old 04-06-2020, 11:53 AM
guyton44 guyton44 is offline
Every thing is back to normal! I cranked it up later in the day and it is charging correctly. I had to use jumper cables the first time I cranked it and that is when the problem began. I read somewhere that a generator motor will correct itself when the generator goes from the starter mode to the generator mode. That seems to be what happened. I used it again this morning and it is charging correctly. Thanks to everyone who tried to help me.
Old 04-06-2020, 11:57 AM
Sounds good....!!!
