![]() Quote:
Either way thise numbers seem really low for a fresh build. Also there should be no mre than 10 psi difference between cylinders. A fresh build usually comes within 1 to 2 psi across cylinders. Also, did you do a leak down test?
I'm thinking those are low numbers too. I'd also do a leak down test to see if you have any other issues. Maybe even try and switch the plug wires and coil connections too. What carb is on your engine?
