Old 01-07-2020, 12:12 PM
yeahkkyle yeahkkyle is offline
Originally Posted by mortten View Post
If it’s a newer engine maybe the timing hole is on the left side of the blower housing like on an AQS engine.
I've looked everywhere on the blower housing(left and right side) and cannot find a hole. I'm thinking I might just pull the engine anyway. I want to fix it up for Spring time so I have plenty of time to slowly tinker with it. With the engine out it will be easier and I can work on a few other things easier.
149, 44a, 54'' snow plow
Old 02-23-2020, 10:02 AM
I finally got around to installing the mule drive and the deck. I believe it is the incorrect deck. Just looking for confirmation from someone. The deck is a 44A which from a quick search came on the QL series correct? So it has the offset center pulley. I need a 44c deck for my 149?
When I installed the deck the center pulley hits the mule drive so I can't even lift the deck. I tried posting pictures but it keeps giving me an error.
Old 02-23-2020, 10:49 AM
Well after talking to a local guy it looks like my mule drive is for a 38/42” deck. He will either trade me decks or mule drives. Should I keep the 44A deck or go to a 42”? Which one cuts better?
Old 02-23-2020, 12:28 PM
A pic of my mule drive. After doing more research I do have the wrong setup. Guess I either find a 38/42” deck or find the correct mule drive for my 44a.
File Type: jpg 264E1034-90A2-4B6F-BDBC-F372B2AAA1A2.jpg (29.5 KB, 66 views)
Old 03-07-2020, 03:45 PM
I met up with a guy and swapped mule drives for the correct one for my 44a deck. Everything is all good now except it sounds like I have a spindle bearing going bad. Pulled mine apart and I have the water pump style ST-745. I can get the newer aluminum housing style for $30/pc local. What is your guys opinion? Should I go to the newer style aluminum housing with replaceable bearings or replace with the original ST-745 bearings which I will grease regularly and probably get 20+ years out of them?
Also I’m having issues sending private messages. Type it out and send but the message never goes to my sent folder.
Old 03-07-2020, 03:57 PM
ironman's Avatar
ironman ironman is offline
Personally, I am not familiar with a "newer style aluminum housing spindle" that would fit an older Cub deck. Can you post a picture or a part number??
Old 03-07-2020, 04:12 PM
I’ve been reading a few posts on this forum of guys who swap in the spindles off a 50c deck.
