Making Quiet Lines Great Again!
Nice looking tractor!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
Any progress on the tractor?
An update on the 1450. Since I went back into the workforce (OTR truck driver), I have very little time for my toys
. It has all the usual Quietline issues plus a few extra. The engine valves were not the best so they will be replaced too. Items to be repaired; new engine mounts, new driveline parts, replace muffler and air duct/box around muffler and weld several cracked places on the chassis and hood. The oil pan was badly worn from bad mounts...a new one will be installed.
Queen Of The Quietlines!
Looks like they got there use out of that one, do you have a better frame in your stash?
Up to 534 and counting... I give up updating my profile! |
An update...it has only been four months. I dunno...a glacier makes more progress moving along than I do working on these tractors! The frame was cracked in several places. I don't have any donor frames right now so welding it was the next best option. The right front spindle is very sloppy in the axle casting. I do have extra spindles and wide frame axles available.....but...was thinking of installing a "cyclops" style axle. I have two styles available. This is an experiment so I need input as to what will be the best choice. This tractor will be used to mow, till and remove snow. As always PICS!
Should I install a "cyclops" style axle?
Depends on whatcha using it for as it will raise the front up. I see one may be from the early style cyclops that came on a 1541 and such. That one would not raise the front.
