Old 04-30-2009, 10:28 PM
Originally Posted by JMD View Post
Set the timing the gap will be right.
Yep. Due to wear and manufacturing tolerances, a .020" point gap isn't necessarily going mean that it's properly timed. Connect an ohmmeter to the the points such that the resistance is 0 when the points are closed and infinity when they are open. Turn the flywheel in the direction of normal rotation. When the points just start to break (the resistance will waver before going to infinity) the "S" mark will be under the roll pin in a KT-17 or in the sight hole in a K-series. The gap may vary quite a bit from the .020" spec.
Old 04-30-2009, 11:14 PM
JMD JMD is offline
Smile Ignition Timing
Thanks Matt you said it better then I did for all who don't have a Ohm Meter you can use a simple 12 volt bulb & socket with two leads and alligator clips conected to the points and ground when bulb lites at the proper timing mark you are good to go. Turn on Ignition switch first motor doesn't have to be running this is called static timing the engine. turn engine over by hand slow. Read your manual for proper fireing mark. I don't know if the S mark is the fire Mark on all Cubs.
Old 04-30-2009, 11:31 PM
wig wig is offline
Default Timing
Understanding the "timing mark" in the manual is not real clear. I have a meter to use and when I rotate the engine looking at flywheel end, rotating clockwise, when the points just start to break or break there are to marks on the flywhhel. "TDC" and "S". There is a rollpin on the side of engine block for position of those marks to be in relation to roll pin. Manual says the "S" should be "just opposite" of the rollpin when points break.Do the mean just past when traveling clockwise?
Old 05-01-2009, 12:38 AM
JMD JMD is offline
Smile
According to Matt who knows your motor the S mark will be under the roll pin. Hope this helps
Old 05-01-2009, 01:43 PM
To further clarify...this is what you want:
